First time Zwift user so this might be operator error, but… My bike with Assioma Duo pedals paired to both pedals in Zwift, but only showed power for one when I was riding. Passed by everyone as I was basically Zwifting with one leg. Tried my other bike with Shimano power meter cranks and Zwift worked perfectly. How do I get Zwift to read both Assioma pedals power? Any suggestions would be appreciated.
Zwift only pair to the left pedal because the right pedal sends the power to the left then the left combines it and broadcast it.
Use the default settings on the pedals.
Thanks very much for the help. Worked right away.
How do I use the default settings on pedals? I’m having the same problem
It isn’t just that.
If you go into the compatibility with other apps section you need to make sure that is also set to send power for both through the left pedal.
I use the favero assioma duo in standard mode and it works.
I dont understand why I cannot see the balance L R when exporting the fit file.
