Assimo Power meter pedal setup
I got my Assimo uno pedals and set them up yesterday. On first test they are working well and it looks like the watts guestimation from my Sole SB900 spin bike was about 40% higher than reality at the same cadence.
What I wanted to check was in Zwift, I connected the pedals via the power meter option. I also connected them via the cadence connection. Is this correct or should I only connect via the power meter?
Can I also confirm that you keep the “double the power option” for Uno’s OFF? It seems this is only required in connecting via bluetooth and I assume Zwift is using the ANT+ connection?
Thanks!
