Application failed
just when I go through the finish line it gets stuck and leaves the application !! it does not record the route or anything
Are you running Zwift in the Spanish language? Because quite a few people have found the same problem, and the workaround is to use English.
If I run it in Spanish, it was put like this in the last update !! and where should I put it to run in English? Thanks
I believe that you can change the language in the Pairing screen.
ok thank you very much I will try it next time !! is that he has already done it three times and it is a bummer.
and thank you for answering and helping!
Have a look through some of the Spanish threads on this. My poor Spanish can only let me get the gist of this sort of thing - Se apaga zwift cuando finalizó la carrera
