When using an Apple TV to run Zwift, the Companion app is not syncing with HealthKit, therefore it is unable to log activity. However, it works most of the time when running Zwift through your iPad or iPhone.
This has been a widely know issue for quite some time now. Can we please get some momentum behind resolving this issue? It’s killing the experience! If it’s not going to work, don’t use it in your marketing material.
Not working for me, while running zwift on windows. And the companion app on iPhone. It used to work over a year ago but since a year already no luck. Pleas fix!
Please fix this issue. I used to use Strava as an intermediary (i.e. sending the data to Strava and then Strava writing to Health app). But Strava updated their iPhone app on Feb 13, 2020 and now it writes only natively recorded workouts to Health.
Given that, I have no way of getting my Zwift data to Health unless I change my set up (Zwift on Windows with Ant+ receivers and Zwift Companion on iPhone)
I’ve spent days puzzling over this! Yes as James says, Strava used to work as an intermediary but now no longer sends cycling data. I’ll log a ticket with them (although I don’t expect much as I’m only a free memebr).
I can see that the Companion app will sync Running & Walking, but not Cycling!
Please fix as well. the iphone Zwift app shows up in health data, but the companion app does not. I want to continue to use an apple TV for the Zwift app and my phone for the companion app
I’m using an iPad to run Zwift. On my iPhone I have ZC app, but it does not show up in my list of apps that have requested access to health data. As such, I have to manually enter ride data into the health app. Please fix the ZC to show as a Health App choice.
Since my original post in January, several issues similar to this have basically been completely ignored. I’ve come to expect this from Zwift now: you get what you get and you should be thankful.
Hi Devin - I finally got this to work today. I had to delete both apps from the iPhone and only install the Companion app. As soon as I launched the AppleTV and ZC it asked for permissions to Health data. Did a quick test run and it saved it as a workout in activity. Hoping it’ll work long term. Let me know if this works for you.
Reviving this topic… I have a variation. I run Zwift on an iPad, and the Companion App on an iPhone. I use a HRM that is connected to the iPad when Zwift starts.
I get time, active calories, total calories and average heart rate written to HealthKit from the Companion app
I get distance for the same ride written to HealthKit thru Strava.
What’s missing is the Heart Rate graph. I get a “chart unavailable” error with the explanation that there were “not enough heart rate measurements to create a chart”.
Is anybody getting a full heart rate graph/chart written to HealthKit when using Zwift?
Thanks Devin. So using an iPad you get a full HR trace/chart written to Apple Fitness or HealthKit? What do you use for recording HR? A HRM strap? A watch?
At that time I was actually using my Apple Watch … but that continually proves problematic. I bought a Wahoo Tickr and it’s been flawless. I get full Health data.
