Anti Aliasing Filter for jagged edges on diagonal lines
Using a very capable gaming laptop with 1080p display, some edges and diagonal lines have jagged edges or scintillating pixels. This is usually due to lack of anti aliasing filter. Any way to enable or enhance anti aliasing filter to reduce this artifacts?
I tried setting “set gFXAA=1“ in the high and ultra config files (as explained in https://zwiftinsider.com/config-file-tweaks/), but this didn’t seem to help.
Any advice on how to improve these artifacts?
Choose the 1440p option in the settings menu if you see it, the impact on frame rates over 1080p is negligible. Even better is 2160p but that really does need a lot more more grunt. You don’t need to match your setting to your display, going above brings a nice AA effect.
Thanks for the advice.
Too bad the game doesn’t have a better Anti-Aliasing filter.
I decided to return the Razer Blade 17 Pro laptop with 1080p display and once available, I’ll get the Razer Blade 17 Pro laptop with 4K display.
Thanks.
