Hi all,
Trying to get some advice on ANT+. Currently using a TACX FLUX S trainer.
Background
I am running Zwift on a MBP with an ANT+ within 3 feet of HRM, Cadence sensor & trainer by using an extension cable.
Zwift pairing screen is showing ANT+ connected with both power source, cadence & heart rate at start up. Everything looks good here and I start using Zwift.
Problems
About 15-20 min into the ride, avatar stops moving. “-” appears under Watts, RPM & BPM.
I stop riding on the trainer, go to pairing & check out what happens under the pairing screen.
HRM, Power source & cadence show the pairing with their previously paired equipment but with a “No signal” warning.
I normally save the ride, re-start zwift & when going into the pairing screen in the new instance of Zwift, paired sources now successfully show up without any “no signal” message. And the cycle repeats within half an hour.
On my most recent ride, I did not do that but kept persisting with trying to re-pair in the existing instance of Zwift.
The strange thing is when I go to zwiftalizer to analyze the file, it shows an absolutely strong signal. The problem occurred just after 1050pm. And I resumed riding after the signal was picked up again slightly after 11pm.
During that period between 1050-11, you can see that the signal is maxed out and consistent, better than when the ANT+ signals were actually being read prior to 1050pm. But zwift kept showing “no signal”. I cannot reconcile “no signal” showing on Zwift pairing and yet the signal showing at 100%.
Has anyone else experienced this or know how to troubleshoot this?
