Yes I was concentrating on SZR race but your right about Evo race?
Same deal as SZR except that the EVO race looks to be set up to upgrade riders to the back of their ZP category group. Theyâll need to update their series settings so that the Zwiftpower categories arenât enforced.
Thanks. I assume Iâm probably in the wrong place⌠zwift[dot]com/settings/profile? All I see is a toggle to display my age (or not)
Try Zwiftpower @Wannie
Doh! Found that now, but doesnât explain a couple things. Height is not a selectable share/not share thing. Weight itself is from main zwift account settings since this isnât choosable in ZP? And the wording on HR makes me think that that I wouldnât be eligible to show in results unless I opt in to share? âI give consent for zwiftpower,com to display my heart rate as part of the full results service and for this information to be used for performance monitoring.â
@Wannie that option includes heart rate, weight, and age; itâs badly worded.
@James_Zwift canât beleave it, did a 3R race last night and same deal?
I donât manage the 3R races. You should approach the organiser @Marc_Swatton_R3R
@James_Zwift Am I correct in saying that if the race has âZwiftpower category overrides wkgâ in the info at the top of the page that it will override the category enforcement? If so then there are an awful lot of CE races that have this set, including the Zracing Series
I think itâs the category rules (WKG Enforcement vs No Category Enforcement) that causes the issue.
Because youâll know what Iâm talking about - I have default rules for Zwift events to ensure that this does not happen, but because the. name (Get Rolling) isnât included in any of my default rule sets and I didnât add it prior to creating the events, it uses Zwiftpower default settings.
I think the description No Category Enforcement is confusing for some oragnizers because we use Category EnforcementâŚbut Zwiftpower Category Enforcement is based on ZP Category.
I have everything off but i think we could use WKG Upgrade or WKG EnforcementâŚmy view is that we should still enforce category boundaries.
Yeah, youâre right - there are so many references to CE that isnât obvious what each setting does so I donât blame organisers for not getting it right sometimes. Like you I just have them all turned off in ZP and let Zwift do the enforcement at their end.
Thanks⌠Lol, more than badly worded if weight, age and height are also supposed to be inferred from the provided sentence.
So, what, if any, downside is there to turning off the permission on this item? I see those who I guess have done so are appearing in ZP race results, but are there races with a tag where this wouldnât be the case? ie. What Zwifthacks event rule tag should I look for?
In terms of DQ, there wouldnât be one? â I assume you still need to have an HR monitor running though.
@Wannie Iâd likely someone not displaying those values, if I noticed. Zwiftpower will not auto apply a DQ because, as you say, you are wearing a HRM however, race organisers and opponents will not.
