Age caravory incorrect in Zwift power. Says 50 but im currently 49? How can I correct
Zwift Power bases your age category the same way most race organizers do and it’s based on the age you’ll be at the end of the year. I assume you’ll be 50 by the end of 2024 which is why you’re in that age category.
Well there it is. You learn things every day. Thanks. ![]()
Many sports use similar systems based on competitors’ ages at a specific date. Means if someone qualifies for a series of events at the start of the season, they aren’t suddenly ineligible mid-season (and saves organizers the hassle of having to check birth dates other than once at first sign-up).
Can you not just change your age to 48, then when you get close to your 50th, change it back to 49?
