It would be great to enable a sound option that would play the role of a metronome for workouts that focus on changes in cadence. Zwifters could therefore easily follow the beeps to be sure they are at the right pace, especially when the sections are short and the change of rhythm is significant.
Thank you in advance for your interest and looking forward to seeing this new feature integrated into your software.
I wish an option in erg mode the avatars legs would rotate in the RPM the training wants me to spin.
This would make it easy to visually adapt the cadence instead of looking to a small number on the screen and then over- & underrotate until I find the right cadence.
Like a leg metronom. What do you think?
I think most people just look at the numbers.
I think it’s better to show what you’re doing than what you should be doing.
If we would have real time cadence tracking on every trainer I might agree but in my Case (TacX Neo) there is a delay of Cadence and sometimes Zwift is saying for some seconds „80“ followed by „105“ but reality was I cycleded around 92 pretty proper.
This „sometimes“ is pretty permanent and to be true I have often no idea if Im really loosing a little cadence or its just a measuring thing.
I think this might appear because the trainer can only estimate cadence because of power fluctuation on the chain movement. I mean 1 rpm is not really measured - depending on gear its more or less chain movement so Neo Trainer must estimate because of power fluctuation of chain rotation which seems not always to run proper.
I just think a Button to activate Avatars Metronom Legs within the Settings wouldnt hurt those who are fine with the numbers.
If you want real-time and accurate cadence its probably better to get a dedicated cadence sensor (I think Wahoo have a BT/ANT compatible one) and then use your bike computer (or equivalent Android/iOS app) to view it (I’m not sure if Zwift display the data after a round trip to the server or locally in the client).
Thets the point. I don‘t need real time cadence but so the cadence is innacurate the cadence numbers do not work good for regulation of cadence training. Sure you can upgrade technically. But does everyone need to?
Exactly the point where my Metronom Legs of the avatar starts making its sense.
For all cyclists who just need a little optical support to find the cadence without the will to spent extra money to sensors.
Metronome tick-tack, or just tire noise in sync with required cadence to keep it steady during the interval.
For training sessions where a specific tempo needs to be maintained, add a metronome option to help keep the tempo correct.
Recently overheard…
Some archived feature requests for this
Pick some music with the right tempo.
However, more riders find success in picking music tempo to match their target heart rate.
On workouts with set cadence targets, it would be really helpful to have a toggle’able metronome that hits the target cadence.
I find it take me a couple of seconds to get my cadence in line, and this would help.
Love #Zwift! ![]()
I like the idea.. nice contrast with folks trying to work out how to get rid of some mysterious click or noise from their setup. ![]()
