The awesome new feature for “Coffee break” gave me an idea: You’ve been there too… within the first 5 minutes of a ride you realize you left your bottle on the counter, or your quick release is coming loose, or your fan is unplugged … all you need is 60 seconds to adjust something but you don’t want to get dropped from the group you’re in. I think Zwift should add a Tinker or Fiddle button to give you 60 seconds to do something, but it goes away after 5 minutes into a ride. Thoughts?
This feature would be nice to have. I typically notice something is “off” within the first 5 minutes of a ride. It would nice to fix the “something is off” feeling without having to end the ride, fix the problem, and then restart the ride.
the coffee break already gives you 30 seconds during the first 5 minutes… are you asking that to be extended to 60 seconds?
I’m looking forward to the teleport feature so that I can stop and swap bikes and take as long or as little time as I’d like and then teleport back to the group. I think that’ll be much more useful in the long term than the coffee break.
Does it? I wasn’t aware that was a thing. Not intuitive whatsoever if so, but I’ll take it.
Just keep in mind that the 30 seconds is in the first 5 minutes after your avatar spawns, NOT from when the event starts. So, be sure you check everything out quickly.
