The third MAAP ride showed the initial route and the portal route as Willunga hill a 2.5 mile ascent
When riding into the portal we were met with a 9.5 mile climb consisting of two additional hills
If I had known this route I would have had nutrition and electrolytes for the ride
Power to the Portal is a brand new route added in with the 1.79; Off the MAAP is the first to be able to use it.
I would however indeed hope in the future it can display things correctly and have the right data.
Just checked Companion and you’re correct; it only shows the data for Power to the Portal; but “no map available.”
At some point in the future, we are “told”, clubs and event leaders can set the route with whatever climb we want… so I’d hope this is fixed by public use time.
(Perhaps someone just ‘forgot’ about this after the decently smart addition that is Power to the Portal?)
I would hope and assume however by… some point in time… seeing as how Climb Portal is coming up on 2 years old! We would have… something to see in Companion App. Whether it be a side grade view, or anything…
Why didn’t it show Willunga hill?
I would assume it’s not a feature of companion / Zwift itself.
The information fortunately is in the event description though.
