Good Day,
I do Brick and Triathlon HiiT Workouts, so would switch between bike and treadmill as part of the workout.
The problem is that when I start running the bike gets disconnected.
Are you not able to use one account simultaneously on a different devices?
No, you can only be logged into one device using your account at a time.
thank you.
That is a shame, to have to log in and out during a workout
If you have the option of using the same device for both riding and running you don’t need to log out to switch from run to bike.
thanks Mike, the problem is then I would have to end the ride or run.
and the treadmill is on one Apple TV and the bike on another
Hey Clause, Im not sure. Great suggestion, I will double check
Thank you
