3rd Person view too close
Hey ya all.
My third person view seems way too close. Have restarted and tried another pc which seems further away. Have tried close 3rd person too etc.
Any ideas anyone please.
Excuse the 40k.
Have you recently changed bikes? Or do you have play controllers (possibly the click too, I don’t have those so can’t confirm this but someone else might be able to) that you didn’t connect?
This is a known issue that happens after a bike change or if controllers are disconnected or not initially paired. Not heard of any fix being worked on though.
Should fix itself on the next ride or when the controllers are reconnected.
Ah okay. I changed to a Tron bike in the pens and the zwift play controllers connected fine as usual.
I’ll change back to the other bike I had and see if that makes a difference.
Yeah this bug happens when you change your bike.
The second ride with changed bike, the FOV will be back to normal again
The easiest fix i have found is to just turn off my right play controller and then turn it back on. It will automatically re-pair and fix the zoom.
