Zwiftpower not bringing in activities for several days
Zwiftpower has not imported my activities since Monday despite having several rides visible in Companion and doing the manual update under the ZP activities tab.
I’ve been riding every day, and not seeing any gaps in my activities either on the activities tab or on my ZwiftPower profile (which by design shows only events, not solo free rides or workouts).
Have you noticed that your last three rides, which were races, show you as DNF in the Zwift results. DNFs do not go through to ZwiftPower, although generally show in the Live tab. You probably should be checking why your Zwift activities are not saving properly.
Edit: did you actually finish the three races? If you did not finish a ‘ZwiftPower qualifying’ event then the activity will not show on your ZwiftPower Profile page. If you check your Activities tab in ZwiftPower I think you should find your activities showing there provided minimum distance has been reached.
:backhand_index_pointing_up: could also be caused by a shadow ban
His account shows correct name - does a shadow ban not come out as Watopian in review?
I believe it did at some point. I don’t know if that’s still the case. If that changed I wouldn’t expect it to be mentioned.
I have updated my original post to offer him another possibility.
I see activities from yesterday so I imagine this is fixed now?
I spoke to Joel about it. They were true DNFs due to not finishing so nothing bad happened AFAIK
It pulled in all those DNF activities now. I am showing everything up to date. Not sure what the problems was, but it appears to be good now.
