Zwift Ride chain skipping cog v2
Hi!
I just installed my Zwift Ride with the Wahoo Cog V2, and I’m having a rather annoying issue:
:backhand_index_pointing_right: When I pedal forward, especially at a high cadence, the chain jerks regularly, as if it’s catching or jumping a little with each turn.
I’ve already tried several Cog positions (different numbers), everything is tight, the chain is tight… but nothing works, the jerks persist.
Have any of you had the same issue?
Did you find a solution or was it a hardware defect?
Thanks for your feedback :folded_hands:
I installed a couple weeks ago. I found on my set-up the Cog worked best and quietest on the lower chainring. Could your chain need to be replaced (stretched)?
Sur quel plateau avez vous réglé ?
Hi @Laureen_BIKES welcome to Zwift forums.
Shuji at Zwift HQ here. I see that you have been talking to my Support team colleagues. Thank you very much for including videos! This is very helpful in cases where we need to see and hear what’s happening on your end.
I’d like to ask you to continue your conversation via email so that we have some continuity in your support ticket.
Is your chain compatible? I believe mine is a Sram flat top AXS. T-type might be different
Hi, did you come to a solution? I think I have the same issue.
