Zwift Ride 7x9 saddle rails
I just got a zwift ride but find the stock saddle very uncomforatble. I have another saddle i’d like to use but it has 7x9 saddle rails. Is there an adapter or different clamp I can get to utilize this other saddle? thanks
Is that a carbon saddle? Normal saddles should fit the standard 7mm rails on the Ride.
Yes, it’s a carbon saddle.
Sadly it’s a proprietary seatpost with no clamp options. The Ride is packed with proprietary bits so you have to live with it or hack it. Imagine if it came with a 27.2mm round seat post…
Is it a side-clamping clamp, or does it clamp from the top and bottom? If it’s top-bottom, it will work with oval rails just fine.
Pics say :-1:
Ah, yep. Side-clamper. Out of luck.
I’m new to bike hardware. Are there not universal sizes to these side clamps? I see there are clamp adapters for oval rails and wondering why these couldn’t just be swapped out from the stock zwift ride ones.
That I don’t know–haven’t had a chance to look at the parts, see if they are compatible. The whole clamp would have to be replaced–the central part and the moveable sides.
Hi @L_onestar welcome to Zwift forums and Zwift in general.
Shuji at Zwift HQ here. We don’t offer 7x9mm adapters for carbon-railed saddles on the Zwift Ride smart frame, and advise strongly against “hacking” together your own adapters from a rider safety viewpoint.
Zwift Ride exists to offer the ride feel and feature set of expensive smart bikes, but at a fraction of their cost. Compatibility with the highest-end carbon-railed saddles was therefore not part of its must-have deliverables considerations, especially as the weight savings of a carbon saddle is of no benefit on an indoor trainer bike.
Do you have other spare saddles sitting around that use round metal rails? Most saddle manufacturers that offer their premium models in a carbon-railed version make stainless steel / titanium / hollow Cr-Mo steel versions as well.
I can take off my round-rails saddle from my current bike and plan to use this one, its just that I got the carbon saddle recenlty but need to get adapters to use it on my road bike too.
has anyone found a solution to this? any adapters?
Different saddle is the solution for now as far as I know
I know i’m a bit late, but you can just put it on anyway.
Its not the “right way” to do it, but it works if you don’t have another saddle. I have a 7x9 carbon saddle on mine for 4 months and it’s fine.
Given rider preferences to keep like equipment across multiple bikes and knowing that the cheap alloy railed saddle is not 1=1 with the more expensive option, I’m shocked at this response to be blunt. I hope these riders find a solution soon.
While I can perfectly understand support for 7x9mm cabon rails was not a must have during the initial design phase, now two years later recognizing the considerable market demand also due to cheap offerings and no longer limitations to high-end it would be more than time to offer a suitable adpater. Even if not shipped with the base version, but then at least as an option to buy. Quite frustrating to have saddles known to be nice fitting but than having to look for an alternative with 7mm round rails. Any update from the Zwift HQ @shooj ?
@Eric_Hubert. We’ll update this thread when there’s news to deliver.
Not an official Zwift response, but it is a solution that works for me. Sharing here so others can hopefully avoid the hassle of buying incorrect parts that I went through first.
Grab a Specialized Anodized Pave 7mm/9mm Clamp (part 2812-9050). I don’t know why it’s spelled “anodize” vs. “anodized” on the package. Maybe that’s why Specialized has them 50% off right now on their site :joy:. My nearest bike shop is a Specialized dealer and had it in stock.
Bonus: it includes the clamps to fit standard 7mm round rails and 9mm oval/carbon rails, so you don’t have to use the spring-loaded Zwift Ride version that has a tendency to bounce across the room for me.
You lose the little white dash that the Zwift Ride version has to adjust your seat angle. I always use a 0º angle and prefer a level to do that, so that didn’t really bother me.
You’re an absolute star! Just bought a saddle on eBay at a VERY good price, not realising that it had oval carbon rails…and it’s non returnable. This work around now means that I can use the saddle. OUTSTANDING!
If you can wait a little for delivery just replaced mine from ali express for about £13
