Can anyone briefly explain race cats to me?. Im C cat but last Thurs and tonight raced over 37 mins at 3.4w/kg? Not angling to be B as I know i can enter those but understood B to be 3.2+
Hereās the detail on how pace groups are calculated for the purpose of category enforcement. Note itās using your zFTP, and zMAP that you should see to the right of your activity feed on zwift.com. These are based on any effort in Zwift, not just races:
Thanksā¦seems my zmap is too low to be shunted to Bš. Happy days
Unfortunately the documentation is not correct. If either your zMAP or zFTP reaches the threshold (assuming you are above the Watt floor) you will be upgraded. This was confirmed recently by Zwift staff.
Personally when I get back to B I will not enjoy having my doors blown off, but I will never let that hold me back once Iām in a race. I recommend an attitude of āgame onā and the devil take the hindmost.
Oh ha, I thought they said they were gonna fix that. Yeah, itās either, does not need to be both.
So, my w/kg of 3.4 in 2 races should =B? Zwiftpower says C but assuming a lag in updating? Maybe 1 last hurrah in C beckons
No thatās not how it works. Look at your PRs on my.zwift.com. See the zFTP and zMAP values. Calculate your weight as the average of the weights from the PRs you set in the last 90 days. Use that to divide the zFTP and zMAP values. Thatās what they use to figure out where you land on the category threshold table. A single race or any ride will do it if you get there. Never manipulate your weight on free rides or youāll get there faster. (Or just race and donāt think about it if you prefer.)
By the way if you compare the numbers on your ZwiftPower profile to mine, youāll see that you have some headroom still in C. Still as a lighter rider itās much easier for you to get upgraded.
Cheers ![]()
