Zwift play possibillities
So what’s possible with zwift play?
I’ve seen the marketing stuff, i mean besides zwift.
Will i be able to low level hook the inputs and use certain buttons to control media buttons or do other things than what zwift thinks it should?
What about emulating the zwift play with an arduino so that i can send ride-on bombs with a single button?
I’m curious, as the only feature on the play that i really want is the ride-on bomb.
The companion app is SO annoying to use for that, and there doesn’t seem to be a keyboard shortcut for some reason…
You can do ride on bombs with the Zwift Play but at the minute the buttons can’t be programmed for other uses.
Never say never though.
You can also return a ride on using the Play.
This tells you all.
Hi I want the same things and posted a topic for that.
