I ride a mountain bike on a Wahoo KICKR and find the gearing leaves me spinning out on flat ground. It would be nice if I could adjust my gearing in Zwift, whereby Zwift would control the KICKR by starting at a higher resistance.
And in addition to this, a MTB course with longer and/or steep uphills would be very nice. I think there are enough hills in Watopia to ride them offroad ![]()
greetings Hannnes
I also have a problem with spinning out on my MTB (24/32/42)
I’d like something to select “MTB gearing”, or have an option to select chainring size?
I have the same issue. I only have a MTB and I use a seperate Tacx specific tire. I find that Level 3 has me spinning like mad and at level 3 there is no way I will get to the watts that Zwift is asking me too even in my biggest gear ![]()
I have a 2x10 (38-24).
I have the same issue and next time I’ll try to work around by just setting my weight to, let’s try, double the real value.
On the Garmin App there is a calibration where you have to reach 40km/h.
Telling the rider to do so in the highest gear could get a good auto calibration together with a cadence sensor.
But I would be fine just to get an manually to set gearing correction factor.
And by the way that wouldn’t change my wattage/kg data as my workaround will. ![]()
It’s so mad. Zwift is just “to easy” for bikers! ![]()
I also asked the support for adding a setting like “base resistance”, because Zwift on an MTB in Sim mode is no fun in group rides or races. That’s why I always ride in ERg mode (doing workouts).
Watopia and London are just to flat. But you kno, cyclists love distances and hate climbs, and that’s the majority.
Maybe i should build up again my old CX bike ![]()
