My current version is 1.0.54377
Is that the one I should have, if not, how do I force the update?
I see the problem with the latest Zwift update from Aug 13 (1.0.54537). The behavior was slightly different: the crash was immediate instead of the cadence/speed/HR area going blank first.
Iām not sure what to do next. As I noted earlier, I biked Ven-top during the virtual TdF and had no issues, so I donāt think my hardware is struggling to render this world.
Did you change your graphics settings by manually editing config txt files?
I did modify them a long time ago an have never had a problem. With the defualt, the GPU load was very low so I took most settings from the next level. So I modified them according to the suggestions on zwiftinsider.
Thatās a good point though ā let me revert to defaults and see what happens.
Definitely worth a try, a few people I know that had issues with crashing in France all realised they were running modified config files so it seemed to be a common denominator.
Well this definitely helped. I made 4 modifications based on things I read and now France is not crashing.
I do think the system is underutilized with the GPU at 40% and CPU at 15% and system memory at ~50%. I may try to revert some of my changes to get more realism.
The only change doing anything there is the shadow res. Foliage youāve set to 100% which itās on anyway. You should just be on default, these mods arenāt needed on Ultra profile.
Edit: sorry, got your GPU mixed up, not sure youāre on Ultra. Anyway it seems to be any mods from default that cause instability on France.
Hi Dave,
I am normally running on medium because my GPU isnāt one of the recognized ultra models (Itās an M2000; I also have a K2000 installed). For that reason, I followed the recipe on Zwift Insider to mimic an ultra profile, which had worked up till now. BTW, I do see a difference between foliage 1 and 2, so I may try to dial that up. I donāt see a lot of visual impact of having a lower shadow resolution so far.
Just tried it⦠still crashes with 54537
Yeah I saw that after originally posting.
Foliage at 2 is 200%, so double the amount found on Ultra by default. Itās normally only reduced by the other profiles, not increased. Go steady with that one, itāll put a lot of additional strain on your GPU.
But yeah I think you need to be totally stock to be as sure as possible of avoiding crashes. The frame counter doesnāt seem to cause a problem though.
Processor Intel(R) Core⢠i7-3770K CPU @ 3.50GHz, 3501 Mhz, 4 Core(s), 8 Logical Processor(s)
Name NVIDIA GeForce GTX 1060 6GB
Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_db678424d2641c3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_db678424d2641c3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_db678424d2641c3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_db678424d2641c3d\nvldumdx.dll
Installed Physical Memory (RAM) 32.0 GB
BaseBoard Manufacturer ASRock
BaseBoard Product Z77 Extreme4
OS Name Microsoft Windows 10 Pro
Version 10.0.18362 Build 18362
I have the same issue, twice in a row today on ven top.
