I’ve observed this several times now: every time I update MacOS on my laptop, the Companion app on my phone can no longer connect & display my ride (the “Game” tab).
This is because the app on the laptop loses “local network access” capability after the reinstall.
Moreover, when I go to “security & privacy” settings in MacOS, Zwift doesn’t show in the “local network access” setting.
My workaround is to reinstall the Zwift app on MacOS, and then it will ask for “local network access” on first run.
It definitely sounds like the common denominator is how the Mac Mini and the Android version of the Companion app are “handshaking” after that first install.
While running the installer before every ride is certainly not the ideal experience, I’m glad you found a workaround to keep you spinning while we work on this.
Once we have a definitive solution or a firmware/app update ready, we will publish the announcement directly on our community forums. You can keep an eye on the official “Release Notes” and “Known Issues” sections here: Zwift Forums.
This has been happening for a long time. Super annoying. And no, has nothing to do with Android or the Companion app itself. I’m on iOS, makes no difference. It’s something to do with the Zwift Updater on macOS and not asking for proper permissions upon update. As mentioned, the only workaround is to reinstall Zwift desktop app.
Mac just updated last night, I’ve tried to reinstall Zwift. I can get my trainer to pair but not my heart rate or my Zwift click controllers. Any fix for the other devices?
Which trainer are you using and is it paired via Bluetooth? The model of trainer will also determine whether you have more pairing options you can try.
I have most recent wahoo kickr - apple silicon Mac. Kickr paired via Bluetooth. This happened another time before, seems to be always after an update for Mac comes out. I have triedfast reinstalling and restarting every device. The only thing I havent done is take the batteries out of the controllers and heart rate to reset those.
Is it the Wahoo Kickr V6, or the Wahoo Kickr Core 2? Both of those trainers support pairing via WiFi or Bluetooth, but the Core 2 also has a sensor bridge feature that the V6 does not.
Can you post a picture of your pairing screen? The reason I ask is because if you are pairing the trainer via Bluetooth, there is no permission-related reason why the controls would not pair. But if you are pairing via WiFi, there might still be a permission problem.
