I am unable to log in to the Android Mobile Link App on my phone when connected to the same WiFi, but if I switch WiFi off and use 4G it logs in fine.
I assume there is an issue with my UK BT Broadband provider connecting to my.zwift.com and the address behind the mobile app, maybe a DNS problem but I’m not really sure.
Any pointers on what I could do to resolve this would be much appreciated.
Had a similar issue. I used the auto-correct suggestion for my email. Did not notice it inserted a trailing space. Deleted the trailing space and I was able to login
I’m having the similar issue. I can’t log in to Zwift with Zwift Companion App on Android at ALL. It simply says password incorrect. If I use LTE it just works. I’ve just did:
Connected to WIFI
Launched Zwift Companion App
login screen appeared - I can’t log in using my password
Exited from app
disconnected from WiFI - switched to LTE
I’ve been automagically logged in and moved to home screen
what’s going on guys?
// edit:
fyi, I’ve fixed that myself by clearing out the application data. It is working now!
