Has anyone found the work around for using Zwift Android and also loading up the Companion application at the same time? Are you looking into consolidating the two in the future? I am using one device my Samsung Galaxy S8 Plus
You cannot run both the Zwift app and the Zwift Companion App at the same time on the same device, there is not work around.
Has anyone tried split screen on the samsung? Or will the two apps not run together at all?
When I attempted to do this. I recieved an error message saying, this application (zwift) was unable to run in multi window mode. I have a Samsung Galaxy S8 +
Again, you cannot run the Zwift App and the Zwift Companion App on the same device at the same time. The connection between the 2 programs is done over your local network…
