@Nicolas_Christin_F
There’s no reason why the Eurosport stream should be geo-blocked if you’re located in France.
This is the collection of the Zwift Academy videos, which have all been published. You’re saying that you still get a geo-block message? Is it the same result if you watch on your phone vs. a laptop on the same home network?
Is a VPN / Apple Private Relay active on whatever device you’re using to watch?
@shooj I can confirm that episodes 2-4 are still geo-blocked in France. Also the page you linked only lists episode 1 when accessed from France. I have a residential IP that is correctly geo-located in France by ipinfo.io.
I tried proxying through two VPS I own, one in Germany, one in the US. I can watch all episodes from these IPs (and the page you linked then lists all 5 videos). Which, I guess, solves the problem for me.
