Hi
is it possible to stream a race on youtube with an apple tv? can i grab the signal or is it possilbe to share this with an app?
thx
not that i know of easily without taking the output into a pc with capture card is what i do.
hi can you explain your setup which capture card and how software do you use
From ATV i have a HDMI splitter to push the signal to both the TV I’m watching on and a capture card.
Currently using one of these https://www.amazon.co.uk/gp/product/B00I0QZMPE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
But there a bit old i also have one of these which i capture IPAD stream from https://www.amazon.co.uk/gp/product/B08Z3XDYQ7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Either feeds into the PC running OBS.
I suppose slightly odd setup i had the ATV before the pc other you could say why not just use the PC which i do most the time but if your pc is poor graphically or unstable then using the ATV and just the PC to stream could be a good solution.
