Hello Zwifters!
As of today, October 20th, we have linked up with Xert on yet another seamless training connection! With Zwift’s new training API, you can simply Link It, Zwift it, and Track It, removing the steps before and after the workout you want to do on Zwift from a third party platform. The Xert integration allows you to push workouts from Xert → Zwift and once completed, Zwift will send workout data back to Xert for continuous fitness tracking across platforms.
A feature new from Xert is their Forecast AI, which, for Zwifters, allows you to define your end-goal power values. In other words, this feature lets you pick your future power across any duration; huge for when you’re targeting specific segments, key climbs, or route PRs in-game! With this integration, we’ve seamlessly combined Xert’s AI capabilities with Zwift’s socially immersive experience.
Here Is How It Works:
- In order to connect to Xert, you will need to follow Xert’s support article as the first step in the connection.
- Once connected, you will be able to push your cycling workout to Zwift and, once the workout is completed, the activity will automatically sync back to Xert.
- Cycling workouts pushed over for the current day will show up in the “For You” carousel on your Zwift home screen as well as in the Custom Workouts folder.
- Only running workouts from Zwift will be auto-synced back to Xert if you have that option selected in your Xert settings. The API is not set up to support running workouts pushed from Xert.
- Again, once a workout has been completed, that workout will be automatically synced back to Xert for seamless fitness tracking and progress.
FAQs:
Q: How can I connect to Xert?
A: You can follow Xert’s support article here
Q: How can I disconnect my Zwift account from Xert?
A: You can disconnect your Zwift account from a supported partner at any time from the Connections setting on zwift.com. Navigate to Account → Connections, and then select the Disconnect link from the partner section.
Q: What data is shared with Xert?
A: Full activity information including the fit file, virtual GPS data, HR data, power data, and calories will be shared with connected apps.
Q: How many days’ worth of workouts will sync?
A: Xert currently supports pushing your daily workout to Zwift. This workout will automatically appear in the ‘For You’ carousel once pushed from Xert’s platform.
Q: How can I update my scheduled workout dates?
A: In order to reschedule a workout, you can do so using the Xert platform. Once updated, make sure to push it back to Zwift so the update is automatically reflected in Zwift’s home screen.
Q: Why is my activity still showing even though it was scheduled for yesterday?
A: Any given activity will remain visible until 48 hours after the scheduled completion date has passed, then it will be removed from the Xert folder.
