can i use a non motorized treadmill for zwift?
I’m pretty sure you can if you have a foot pod.
looking into the runnTm as well… thank you for your advice
Hi there. I use an Assault Air Runner non motorized treadmill. I use Zwift on Apple TV and connect the Assault Runner via Bluetooth. Works like a charm. To my mind, the best indoor running experience you can find: Zwift + Non-motorized treadmill.
thank you howard, i am using woodway curve trainer, the surface is by far the most amazing thing i have ever run on. i tried the assault and it was not fun, legs took a pounding worse than running on the road…
thank you again for the response.
Did you end up connecting your woodway curve to Zwift?
I got the assault runner and looking into the wooday
Works perfect. Woodway is way better than assault
So it did pair and Zwift reads the data of the woodway?
What device are you running your Zwift on?
Yes using a Runn Smart Sensor
