Since chromebooks have been able to run android apps for a while now I guess there are quite a lot of x86 android devices around these days. There is still no build of Zwift for x86 devices though.
I’m just wanting to know why this is still the case? In general publishing an app to the play store with x86 as well as arm build targets is trivial. Basically just a config change. I also know Zwift runs fine on a lot of the hardware setups in modern chromebooks (the pixelbook go has essentially the same hardware as a low end MacBook Pro that runs Zwift fine). Is there some technical limitation I’m missing that’s stopping you from doing this?
