Hi Community,
first post so pls be patient…
Which rocker plate are you using for the Zwift Ride by zwift?
I‘ve read now this and that but nothing healed my concerns especially regarding the front „placement“.
(Note: rocker plate should be purchaseable in good old Germany…)
Thanks upfront for every recommendation, hint and help!
Ride On!
I don’t use a rocker plate myself, but these guys sell rocker plates that are compatible with Zwift Ride - https://www.turborocks.com/
Hi Steve,
thx for that. Looks nice and solid.
Meanwhile I was in contact with Leeze which sells the Boom Board Pro in Germany. They already confirmed me that it is compatible to the Zwift Ride!
Therefore it is now ordered and I will share my exp once it is setup.
Best
Chris
Hi @RickMave and welcome to the forums! This is Alejandro from Zwift. We’re happy to know you chose Zwift to be part of your fitness life. Don’t hesitate to contact us at support@zwift.com if you need any assistance.
Velocity Rockers’ Delta RS is a great option.
Hi Community,
as promised a short feedback on my rocker plate setup (Leeze Boom Board Pro) as a base for my Zwift Ride after roughly 3 months of testing now.
First of all my main concerns about the front placement: no worries, this is working great. The Zwift Ride stands very stable on the Leeze Boom Board Pro even in case of some heavy sprints with a 100kg body and some 1000W of Power. ![]()
Unfortunately the placement of the trainer (Wahoo Kickr Core) needs some more attention. The fixing with the 5 standard straps delivered with the rocker plate isn’t perfect because the trainers “feet” are round. It somehow works but needs some attempts and time to find the correct “places” (holes) on the board. The trainer simply doesn’t fit perfectly to that fixing method of using straps. Therefore I would recommend to order additional straps to fix the trainer within different angles tight to the boards holes. For me it works now and I’m very satisfied.
Finally I would like to point out that the Leeze support is really helpful and fast in feedback. (No, I’m not paid by them but nowadays a helpful fast and friendly service doesn’t seem to be usual anymore and therefore worth to mention.)
In case of questions just reply or ping me.
Ride on!
