Weight error
My weight is 77kg, but companion app shows that I weight 77000kg. It doesnt change even after i try to update it. I removed the app and installed it again, but nothing changed. What should i do?
Welcome to the Forums, Mikko.
Check out this thread: Weight setting wrong on Companion app
I’m betting that you’re using Android for Companion. The recent update to that app is causing decimal separators to be ignored in certain non-English-language set-ups. As far as I understand, the workaround seems to be to close Companion and adjust your weight using my.zwift.com. Good luck.
