I just started my membership back up and the last time I used Zwift in the spring I had a power/HR graph at the bottom of my screen. I just did a 30 minute ride this evening and it didn’t show up. Was it removed or do I need to do something to get it back? I’m using a Wahoo KICKR CORE with TICKR HR monitor.
You may have accidentally switched it off. Press “g” on your keyboard to switch it on again. If you´re on AppleTV swipe up and then click on the icon with a “graph” on it. You need to do that only once, zwift will remember your choice.
Thanks - that was it. I had an update when I started Zwift up for the first time in 6 months and it had me login again, so probably reset everything to default.
