VO2 and Zwift
Hi all
I’ve recently noticed that VO2 max forms part of the Category Enforcement in Zwift. My fitness watch (Fitbit) suggests my VO2 is around 47 yet Zwift is estimating at 37.9 which, whilst I’m not the fittest guy, does feel very low for an active person my age (35).
If the data going in is the same (max HR, RHR, weight etc) then does anyone know how the two figures come out so wildly different?
Thanks!
It’s Zwifts own determination of VO2 max, called zVO2. They were warned on this forum that using this would cause confusion and should, at the very least, rename it, but just wouldn’t listen.
Hi Colin
Thanks so much for taking the time to reply - well it managed to confuse me so people were right! It just seems so wildly off, gave me a complex that I was even less fit than I thought!
Thanks again
Dan
There are so many different methods out there for calculating VO2max using power, HR, weight etc that very few if any of them provide exactly the same answer.
However you don’t really need to worry, from a Zwift perspective, as having introduced it they have now decided to remove it.
This link gives you latest, I think, info on Category Enforcement:
And if you want short version this is key section:
2. VO2max
With the changes mentioned above, it didn’t make sense to keep using the VO2max value for the category determination for two reasons:
  1. Because VO2max is a metric that already includes weight normalization, it uses the weight currently set in the user account. It is also calculated at the same time the other power metrics (zMAP, zFTP) are. Continuing use of VO2max with these changes would cause inconsistency with the weight average that will be used for the category enforcement moving forward.
  2. The use of zMAP - a proxy of the user’s maximal aerobic capacity - allows us to discontinue using VO2max in the category determination.
