Problem:
The Zwift program runs very poorly on my video editing / gaming workstation (See Specs below)
The video stutters the moment the program is launched.
Stuttering can even be seen in the menus.
Stuttering does not get better or worse with changing video resolution in game,
Review of logs indicates GPU & CPU utilization never go above about 35%
Hardware:
Device name Windows10VideoEditingWS
Processor Intel(R) Core™ i9-10900K CPU @ 3.70GHz 3.70 GHz
Installed RAM 64.0 GB
System type 64-bit operating system, x64-based processor
Graphics Card NVIDIA GeForce RTX 2080 Super
Driver Version 496.49
Operating System:
Windows 10 Pro:
Version 21H1
Installed on 10/17/2020
OS build 19043.1320
Experience Windows Feature Experience Pack 120.2212.3920.0
Zwift Version:
1.0.85684
What I have tried:
No other applications are running
Removed and reinstalled Zwift
Running latest NVIDIA Drivers
Below are the Zwift Logs, and Nvidia Experince logging.
Has anyone had this problem, or have any suggestions on how to fix it?
Zwift Logs:
[10:17:20] GFX_Initialize: GL_version = 3.1.0 NVIDIA 496.49
[10:17:20] GL_vendor = NVIDIA Corporation
[10:17:20] GL_render = NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2
[10:17:20] Checking Extensions
[10:17:20] Calculating Graphics Score
[10:17:20] GFX: Found a vendor/model match for RTX 2080
[10:17:20] Initializing Render Targets
[10:17:20] Initializing Texture Systems
[10:17:20] Shader Loaded successfully. data/shaders/Final/Blur.psh
[10:17:20] Calling initialize_zwift_network()
[10:17:20] NETCLIENT:[INFO] CNL 3.13.0
[10:17:20] NETCLIENT:[INFO] Machine Id: 1-3e84a033-f9ae-43d4-a3a7-60c43434ddee
[10:17:20] Suceeded initializing graphics
[10:17:20] Shader Loaded successfully. data/shaders/Final/GFXDRAW_NoTexture.psh
[10:17:20] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured.psh
[10:17:20] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_Simple.psh
[10:17:20] Shader Loaded successfully. data/shaders/Final/GFXDRAW_Textured_GammaCorrect.psh
[10:17:20] Loading WAD file ‘assets/fonts/font.wad’ with file.
10:17:21] Shader Loaded successfully. data/shaders/Final/GFXDRAW_FontW.psh
[10:17:21] Using ultra graphics profile
[10:17:21] > res 1920x1080(0x)
[10:17:21] Changed resolution to 1920 x 1080 ( NO MSAA )
10:17:21] > sres 2048x2048
[10:17:21] Changed shadow resolution to 2048 x 2048
[10:17:21] Syntax Error. USAGE: set VARNAME=VALUE
[10:17:21] Type ‘listvars’ for list of tweakable variables
[10:17:21] Unknown command “aniso 4”
[10:17:21] > set gSSAO=1
[10:17:21] > set gFXAA=1
[10:17:21] >
[10:17:21] OpenGL 3.1.0 NVIDIA 496.49 initialized
[10:17:21] Graphics Vendor: NVIDIA Corporation
[10:17:21] Graphics Renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2
[10:17:21] RAM: 64GB
[10:17:21] CPU: Intel(R) Core™ i9-10900K CPU @ 3.70GHz
[10:17:22] ANT : ANT USB receiver NOT found
[10:17:22] Loading WAD file ‘assets/UI/Achievements/goals.wad’ with file.
[10:17:33] NETCLIENT:[INFO] TCP disconnected refreshTcpConfigIfNeeded: 0
[10:17:33] NETCLIENT:[INFO] TCP host 52.33.59.1:3023
[10:17:33] NETCLIENT:[INFO] Connecting to TCP server…
[10:17:33] Loading WAD file ‘assets/Workouts/workouts.wad’ with file.
[10:17:34] m_bPackDynamics25CollisionPushBackRemoval: ON (from retrieved feature-flag)
[10:17:34] PD30 ON
[10:17:34] NETCLIENT:[INFO] Auxiliary Controller: TCP
[10:17:34] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:17:34] NETCLIENT:[INFO] Auxiliary Controller started
[10:17:34] NETWORK:error (6) sending player state
[10:17:34] NETWORK:Got the list of worlds
[10:17:35] NETWORK:error (6) sending player state
[10:17:36] NETWORK:GroupEvents: Success: Queried active group events – Count=100.
[10:17:37] NETWORK:error (6) sending player state
[10:17:37] path C:\Users\pipas\Documents\Zwift\Workouts\427345\workouts.files size 659
[10:17:38] NETWORK:error (6) sending player state
[10:17:39] FPS 60.00, 3101, 14640, -2099
[10:17:39] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:17:39] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:17:40] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:17:40] NETWORK:error (6) sending player state
[10:17:40] PairingScreen CTOR
[10:17:40] BLE : Native BLE - Bluetooth Radio Found.
[10:17:40] BLE : Native BLE - Bluetooth Radio is On.
[10:17:41] NETWORK:error (6) sending player state
[10:17:42] Starting critical power curve search job (64034087) mTimeStamp = 10.01501 m_lastSearchTime = 10.01501 calculating=false
[10:17:44] BLE : Starting Native BLE search
[10:17:44] NETWORK:error (6) sending player state
[10:17:45] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:17:45] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:17:46] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:17:46] NETWORK:error (6) sending player state
[10:17:47] FPS 18.42, 3101, 14640, -2099
[10:17:47] NETWORK:error (6) sending player state
[10:17:49] NETWORK:error (6) sending player state
[10:17:50] NETWORK:error (6) sending player state
[10:17:51] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:17:51] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:17:52] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:17:52] NETWORK:error (6) sending player state
[10:17:52] Starting critical power curve search job (64044439) mTimeStamp = 20.38006 m_lastSearchTime = 20.38006 calculating=false
[10:17:53] SaveActivityService::GameLoadLevel Creating New Activity {worldId: 1}
[10:17:53] SaveActivityService::InitializeNewActivity with {worldId: 1, sport: CYCLING}
[10:17:53] SaveActivityService FIT_CreateActivityFile
[10:17:53] ZNet::SaveActivity calling zwift_network::save_activity with {name: Zwift - Watopia, bFinalSave: False, fitFileNameToUpload: C:\Users\pipas\Documents/Zwift/Activities/inProgressActivity.fit, fitFileNameShort: 2021-11-06-10-17-53.fit}
[10:17:53] NETCLIENT:[INFO] Activity Upload: load fit file from path C:\Users\pipas\Documents/Zwift/Activities/inProgressActivity.fit
[10:17:53] GAME_LoadLevel() worldID = 1
[10:17:53] NETCLIENT:[INFO] Activity Upload: fit file is length 584
[10:17:57] Registered segment 94 with hash id 223344604
[10:17:57] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:17:57] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:17:57] CalculateSlinePoint incorrect last spline time (< 1.0), roadId: 0
[10:17:57] CalculateSlinePoint incorrect last spline time (< 1.0), roadId: 23
[10:17:57] CalculateSlinePoint incorrect last spline time (< 1.0), roadId: 35
[10:17:58] CalculateSlinePoint incorrect last spline time (< 1.0), roadId: 99
[10:17:58] CalculateSlinePoint incorrect last spline time (< 1.0), roadId: 127
[10:17:58] STEERING : Steering Mode Set to: None
[10:17:58] Save Profile Request: Repack Ridge Reset
[10:17:58] Profile: shutdown
[10:17:58] Profile bike distance: 7643596
[10:17:58] Loading routes…
[10:17:59] Loading WAD file ‘assets/Humans/Jerseys/Originals/originals_02.wad’ with file.
[10:17:59] FPS 59.88, -372284, 48932, 190112
[10:17:59] Giant dt in app. dt = 5.64
[10:17:59] SaveActivityService::OnNewActivityId {activityId: 941886796030050352, internalId: 0}
[10:17:59] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:17:59] NETWORK:error (6) sending player state
[10:18:00] Shader Loaded successfully. data/shaders/Final/WatopiaDesert_TerrainHeightMap.psh
[10:18:00] NETWORK:error (6) sending player state
[10:18:00] NETWORK:Joining world 1
[10:18:00] NETWORK:Got the list of worlds
[10:18:00] STEERING : Steering Mode Set to: None
[10:18:00] NETWORK:error (8) sending player state
[10:18:00] NETCLIENT:[INFO] Changed to world-map [1,6]
[10:18:00] NETCLIENT:[INFO] UDP host 34.208.114.218:3022
[10:18:00] NETCLIENT:[INFO] Connecting to UDP server…
[10:18:00] NETCLIENT:[INFO] TCP disconnected refreshTcpConfigIfNeeded: 0
[10:18:00] NETCLIENT:[INFO] TCP host 54.214.122.245:3023
[10:18:00] NETCLIENT:[INFO] Connecting to TCP server…
[10:18:00] NETCLIENT:[INFO] Saying hello to TCP server (largest wa is 0)
[10:18:01] NETWORK:error (8) sending player state
[10:18:01] NETCLIENT:[INFO] UDP host 18.237.214.72:3022
[10:18:01] NETCLIENT:[INFO] Connecting to UDP server…
[10:18:03] NETWORK:error (8) sending player state
[10:18:03] NETCLIENT:[INFO] UDP host 34.208.114.218:3022
[10:18:03] NETCLIENT:[INFO] Connecting to UDP server…
[10:18:04] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:18:04] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:18:06] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:18:06] NETCLIENT:[ERROR] Error requesting fan viewed player state: [404]
[10:18:06] NETCLIENT:[INFO] World clock offset updated from +1228145975ms to +1228145972ms (-3ms)
[10:18:07] FPS 55.87, 82839, 9558, -39663
[10:18:07] NETCLIENT:[INFO] World clock offset updated from +1228145972ms to +1228145973ms (+1ms)
[10:18:08] NETCLIENT:[INFO] World clock offset updated from +1228145973ms to +1228145973ms (+0ms)
[10:18:10] NETCLIENT:[INFO] World clock offset updated from +1228145973ms to +1228145973ms (+0ms)
[10:18:11] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:18:11] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:18:12] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:18:15] FPS 60.00, 84573, 9414, -38885
[10:18:16] NETCLIENT:[INFO] World clock offset updated from +1228145973ms to +1228145973ms (+0ms)
[10:18:17] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:18:17] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:18:18] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:18:23] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:18:23] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:18:24] FPS 60.00, 81563, 9593, -40178
[10:18:24] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
[10:18:25] Starting critical power curve search job (64077180) mTimeStamp = 30.39516 m_lastSearchTime = 30.39516 calculating=false
[10:18:29] NETCLIENT:[WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[10:18:29] NETCLIENT:[INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[10:18:30] NETCLIENT:[INFO] Auxiliary Controller attempting to connect to phone at: 192.168.186.197:21587
Nvidia Experince Logs:
Timestamp (Elapsed time in seconds),PID,FPS,99(%) FPS,Render Latency(MSec),CPU Utilization(%),GPU1 Utilization(%),GPU1 Temperature(Degrees celsius),GPU1 Frequency(MHz),GPU1 Memory Frequency(MHz),GPU1 Voltage(Milli Volts),GPU1 Fan1 Speed (RPM),GPU1 Fan2 Speed (RPM),GPU2 Utilization(%),GPU2 Temperature(Degrees celsius),GPU2 Frequency(MHz),GPU2 Memory Frequency(MHz),GPU2 Voltage(Milli Volts),GPU2 Fan1 Speed (RPM),GPU2 Fan2 Speed (RPM),
2.466,13696,1.000,1.000,437.556,8.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
2.905,13696,1.000,1.000,437.556,8.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
3.444,13696,1.000,1.000,437.556,8.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
3.997,13696,1.000,1.000,437.556,8.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
4.432,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
4.986,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
5.419,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
5.966,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
6.405,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
6.947,13696,1.000,0.000,521.016,6.000,19.000,46.000,735.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
7.492,13696,31.000,0.000,36.589,6.000,36.000,46.000,885.000,810.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
7.925,13696,31.000,0.000,36.589,6.000,36.000,46.000,885.000,810.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
8.471,13696,25.000,0.000,36.418,4.000,29.000,49.000,1965.000,7910.000,0.962,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
8.913,13696,25.000,0.000,36.418,4.000,29.000,49.000,1965.000,7910.000,0.962,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
9.459,13696,25.000,0.000,36.418,4.000,29.000,49.000,1965.000,7910.000,0.962,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
10.012,13696,25.000,0.000,36.418,4.000,29.000,49.000,1965.000,7910.000,0.962,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
10.449,13696,17.000,0.000,39.376,0.000,6.000,47.000,885.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
10.997,13696,17.000,0.000,39.376,0.000,6.000,47.000,885.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
11.435,13696,55.000,0.000,39.320,6.000,28.000,47.000,870.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
11.983,13696,55.000,0.000,39.320,6.000,28.000,47.000,870.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
12.421,13696,55.000,0.000,39.320,6.000,28.000,47.000,870.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
12.967,13696,55.000,0.000,39.320,6.000,28.000,47.000,870.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
13.513,13696,23.000,0.000,39.475,0.000,4.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
13.947,13696,23.000,0.000,39.475,0.000,4.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
14.497,13696,60.000,0.000,39.286,5.000,35.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
14.935,13696,60.000,0.000,39.286,5.000,35.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
15.486,13696,25.000,0.000,22.996,1.000,38.000,47.000,885.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
15.929,13696,25.000,0.000,22.996,1.000,38.000,47.000,885.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
16.484,13696,60.000,0.000,39.335,10.000,4.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
17.030,13696,60.000,0.000,39.335,10.000,4.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
17.468,13696,60.000,29.000,39.286,11.000,37.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
18.015,13696,60.000,29.000,39.286,11.000,37.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
18.449,13696,60.000,29.000,39.286,11.000,37.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
18.997,13696,60.000,29.000,39.286,11.000,37.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
19.438,13696,16.000,0.000,38.684,0.000,4.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
19.996,13696,16.000,0.000,38.684,0.000,4.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
20.541,13696,61.000,0.000,39.451,9.000,4.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
20.980,13696,61.000,0.000,39.451,9.000,4.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
21.534,13696,60.000,0.000,39.399,11.000,29.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
21.975,13696,60.000,0.000,39.399,11.000,29.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
22.527,13696,25.000,0.000,39.415,6.000,4.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
22.966,13696,25.000,0.000,39.415,6.000,4.000,47.000,855.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
23.512,13696,60.000,28.000,39.422,10.000,39.000,47.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
24.058,13696,60.000,28.000,39.422,10.000,39.000,47.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
24.498,13696,60.000,28.000,39.441,10.000,39.000,47.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
25.044,13696,60.000,28.000,39.441,10.000,39.000,47.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
25.484,13696,60.000,0.000,39.454,7.000,4.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
26.028,13696,60.000,0.000,39.454,7.000,4.000,47.000,915.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
26.470,13696,60.000,29.000,39.263,10.000,37.000,48.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
27.013,13696,60.000,29.000,39.263,10.000,37.000,48.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
27.559,13696,60.000,29.000,39.244,10.000,37.000,48.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
27.994,13696,60.000,29.000,39.244,10.000,37.000,48.000,900.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
28.537,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
28.973,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
29.519,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
30.064,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
30.500,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
31.044,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
31.485,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
32.024,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
32.576,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
33.013,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
33.557,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
33.988,13696,25.000,0.000,39.448,9.000,4.000,47.000,945.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
35.517,13696,14.000,0.000,35.846,4.000,5.000,46.000,690.000,810.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
36.063,13696,14.000,0.000,35.846,4.000,5.000,46.000,690.000,810.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
36.506,13696,50.000,0.000,35.940,13.000,30.000,47.000,1320.000,5000.000,0.675,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
37.051,13696,50.000,0.000,35.940,13.000,30.000,47.000,1320.000,5000.000,0.675,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
37.595,13696,52.000,0.000,35.955,14.000,18.000,47.000,1320.000,5000.000,0.675,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
38.029,13696,52.000,0.000,35.955,14.000,18.000,47.000,1320.000,5000.000,0.675,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
38.574,13696,23.000,0.000,36.906,7.000,10.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
39.013,13696,23.000,0.000,36.906,7.000,10.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
39.557,13696,61.000,0.000,37.001,15.000,13.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
40.106,13696,61.000,0.000,37.001,15.000,13.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
40.541,13696,60.000,58.000,36.990,15.000,26.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
41.084,13696,60.000,58.000,36.990,15.000,26.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
41.519,13696,25.000,0.000,23.528,10.000,12.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
42.071,13696,25.000,0.000,23.528,10.000,12.000,47.000,765.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
42.512,13696,59.000,0.000,38.526,13.000,17.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
43.058,13696,59.000,0.000,38.526,13.000,17.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
43.603,13696,59.000,15.000,38.439,13.000,17.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
44.035,13696,59.000,15.000,38.439,13.000,17.000,47.000,795.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
44.573,13696,16.000,0.000,38.926,6.000,15.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
45.013,13696,16.000,0.000,38.926,6.000,15.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
45.557,13696,59.000,0.000,40.418,12.000,12.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
46.104,13696,59.000,0.000,40.418,12.000,12.000,47.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
46.534,13696,59.000,0.000,38.899,12.000,12.000,48.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/A
47.075,13696,59.000,0.000,38.899,12.000,12.000,48.000,825.000,5000.000,0.637,0.000,0.000,N/A,N/A,N/A,N/A,N/A,N/A,N/AN/A,N/A,N/A,N/A,N/A,N/AA,N/A,N/A,N/A,N/A,N/A
