Hi all. I have a few questions that some of you guru zwifters will no doubt answer: 1. when in erg mode, workouts, I want to have the speed/cadence and the workout descition (3 mins 110% 1 min 90% etc) much bigger - can I? I don’t care to see the rider avatar.
Can I show the route in a graph / profile for these intervals?
Are there any workouts that actually provide target cadence for each sector?
Zwift runs a graph at the bottom of the screen during workouts and it can be toggled at other times using the ‘G’ key. Whether it shows info what you want(?) I don’t know.
Some workouts set cadence. I won’t do them as it is too hard to match both a power level and cadence at the same time. Most workouts adjust power level to your steady cadence, and you can decide what it is. Some workouts will have a note saying a target RPM.
You can see this by viewing a workout. A mouse-over will usually bring up a description of that segment. I’m pretty sure you can edit and save any workout as you want them.
