Upg result
I got a UPG on Zwift Power. What does it stand for ? Under Power Group ? A search on the Forum is not possible as you need at least four letters . . .
š”šš† - Entering a category below the Minimum Category assigned to you and visible on your profile. Performance is irrelevant.
You had to select the same category as assigned to you by ZwiftPower
Great. A few days before I still was D. Whatever. Does it mean my result doesnā€™t count ?
It depends on what you mean by ā€˜doesnā€™t countā€™. If you mean the summarized general classification on ZwiftPower after all 3 stages, then Iā€™m afraid it wonā€™t count :frowning:
Itā€™s short for ā€œupgradeā€, i.e. you need to upgrade to the next category.
would be nice if you would get an notification of some sorts. Was still D last week. Who to address for that ?
Thereā€™s no notification system. You have to look on Zwiftpower.
If you suggest that the category system should be better integrated with Zwift, then I doubt that anyone here will disagree with you. Though the w/kg system is fundamentally flawed and a results-based system is what is really needed (and is what real-world racing uses).
