For the past few weeks, I’ve been recording the power data from my Zwift activities (Zwift Ride V1 and Core V2) using my Favero Assioma RS2 paired with a Garmin Edge.
The goal is to identify differences in the power data from the Wahoo Core 2.
I noticed this yesterday after a race; I had to enter a “Time Shift” of 34 seconds in ZwiftPower so that the data would match.
I checked the FIT files from the Garmin and Zwift using various tools. I found that the time offset (Date records) in the Zwift FIT file was about 34 to 41 seconds. The data from the Garmin is time-accurate. I didn’t notice anything during the race itself.
I analyzed the Zwift LOG file in TrainerDX—no errors.
Up until now, the time offset in ZwiftPower for me has been 0 or 1 second.
Has anyone had a similar experience? What could be causing this for me?
I can’t answer your question, but what I can do is tell you to check out the Connect App Store and look for “Power2”, where you can track two power sources simultaneously on a Garmin.
You can’t get full details (ie if your primary is a crank arm, secondary as pedals, you won’t get the standing data the assiomas predict). But it’s a clean way to keep dual records in one file as opposed to duplicates and double ride time data.
Here’s a scrub of it on Intervals during some efforts last night:
It can only record the 2nd via ANT+, and you have to find the ID (which is easy on a garmin if you’ve had it connected as a primary before if you go into connections and about).
Anyways, that’s a strange one because Zwift REEEEEEALLY doesn’t like it when times don’t match up (as in, it checks and confirms sync times like almost every minute)
Did your Fit file start 34 seconds after your Assioma? If so that may well be because your Fit file may start at the imaginary start line and not when the starting pen countdown gets to zero.
Thank you very much for your feedback. It’s not the start time. The two FIT files have different start and end times. It’s the timestamp of the data itself.
My findings (analysis using the Garmin FIT SDK tools): The timestamps in the Zwift FIT file and the Garmin FIT file differ by 34 seconds.
Here are two graphs:
Graph showing a 34-second time shift—then they match
I tested the Garmin time reference; it’s fine. The same goes for the MacBook running the Zwift app. According to the TrainerDX LOG analysis, the World Clock is synchronized.
The marked power data has a timestamp of 19:24:13 on Zwift and 17:23:39 on Garmin—34 seconds later. My conclusion would be that Zwift saves the data in the FIT file with a 34-second delay, or shifts the timestamp—for whatever reason—by 34 seconds.
I’m starting to doubt myself—I’m not sure if this is right
I get a wide variety of delays between Zwift and my Wahoo Element Bolt head unit when I dual record. I haven’t been able to figure out what’s actually behind it, but you’re not crazy.
