ultra high wattage on elite volano
I have an Elite Volano, (small version of Turbo Muin) it’s came with misuro B+ integrated, happens that when I start to ride the wattage and speed goes to high, the power goes up to 1200W… how can I set it?
Hi Roberto,
I have seen your previous post. I didn’t understand you but this post makes more sense.
Make sure your ANT+ dongle is close to your trainer.
Here is an interesting post about your setup with comparable issues:
https://support.zwift.com/hc/en-us/community/posts/204819729-Big-watts-with-Turbo-Muin-Misuro-B-
Hi Bastiaan,
Thanks for your response, my ANT dongle is real close to the trainer, right under it.
maybe is  because I’m using a Suunto ANT dongle? I’ve read that this dongle is ANT and not ANT+, can be this a cause?
Other thing is that my trainer doesn’t appear in the trainer list, I have a Elite Volano B+ (with misuro B+ integrated).
Your Suunto ANT might be the problem indeed:
https://www.thisisant.com/developer/ant-plus/ant-antplus-defined
Try to get a new one which supports the ANT+ protocol.
Ok Bastiaan, I’ll do it.
but and regarding my type of trainer, Elite Volano, not in the list?
there is acctualy on the list some equivalent trainer that I should choose? instead of my one?
have you this information?
http://cdn.mos.bikeradar.imdserve.com/images/bikes-and-gear/accessories/resistance-trainer/elite-volano-1453895216963-eyq5sgxre70d-1200-80.jpg
Roberto
I have the same trainer, what trainer did you select in the end for it to work?
