Hello Zwifters!
As of today, we have linked up with TriDot to make syncing activities a breeze. Zwift’s new training API removes the steps before and after doing your workout on Zwift. Now, you can Link It! → Zwift it! → Track It! - the days of manual uploads are gone! The TriDot integration allows you to push workouts from TriDot to Zwift and once completed, Zwift will send workout data back to TriDot.
How it Works:
- In order to connect to TriDot, you will need to follow TriDot’s support article
- Don’t forget to set Zwift as your primary data source upon initial connection in order for the information to be pushed back to TriDot.
- Once connected, you will be able to push your workout to Zwift. For full details on how to push a workout to Zwift, view our Knowledge Base article here.
- Cycling workouts pushed over and scheduled for the current day will show up in the “For You” carousel on your Zwift home screen as well as in the Custom Workouts folder.
- Your TriDot workout will show up in the For You carousel on/within the hour of the scheduled time you set when pushing from TriDot to Zwift.
- Running workouts pushed over will show up in the Custom Workouts folder.
- Once a workout has been completed, Zwift will send the workout activity details back to Tridot in order for the data to be processed.
FAQ’s
Q: How can I connect to TriDot?
A: Initiate the connection on the TriDot side. You can follow the support article here
Q: How can I disconnect from TriDot?
A: You can disconnect your connection from a supported partner at any time from the Connections setting on zwift.com, or the Zwift Companion app. Navigate to Account → Connections, and then select the Disconnect link from the partner section.
Q: What data is shared with TriDot?
A: Full activity information including the fit file, virtual GPS data, HR data, power data, and calories will be shared with connected apps. Just make sure to set Zwift as your primary data source upon initial connection in order for the information to be pushed back to TriDot.
Q: How many days’ worth of workouts will sync? If there are multiple workouts on the same day, will all of them appear?
A: Zwift will display workouts scheduled for the next 7 days. Multiple workouts can be scheduled in a single day.
Q: Will the scheduled workout dates from the partner app be indicated in Zwift (e.g Monday’s workout, Wednesday’s Workout, etc.) when viewed in the custom workout folder?
A: TriDot includes the date the activity is scheduled for in the name of the activity.
Q: How can I update my scheduled workout dates?
A: In order to update the date in which your workout is scheduled, you can do so using the TriDot platform. Once updated, make sure to push it back to Zwift so the update is reflected.
Q: Why is my activity still showing even though it was scheduled for yesterday?
A: Any given activity will remain visible until 48 hours after the scheduled completion date has passed, then it will be removed from the TriDot folder.
Q: Will additional training apps be integrated in a similar way?
A: Yes! We’ve started with TriDot as our initial partner and will be announcing more partnerships in the coming months.
