Trainer Difficulty percentage setting
Hey there,
Resetting some of my setting the other day and realised, that there was no way to adjust the trainer to an exact base percentage, we live in a metric world… could we be able to adjust trainer difficulty in 5% increments, we aren’t children… i personally like hard fact details so i know what percentage my trainer is set at… a slide rule doesn’t cut it
In Windows, and similarly for macOS, you can manually adjust the Trainer Difficulty. This can be done by setting any specific percentage you desire in the “prefs.xml” file, which is found within the “Zwift” folder located in your “Documents” directory.
The setting is all the way down and called: <TRAINER_EFFECT>
@John_Farrell1
It’s a joke. It has been requested many times. How hard would it be to put some marks on the slider. (Copy and paste a 10 cm ruler on top of the slider)
this is not the job of the end user… PS, i just tried to install ram… and thats as far as i go normally
“If the mountain will not come to Mohammed, Mohammed will go to the mountain”
My life is too brief to wait for Zwift to do anything :wink:
Just set it to max. That way you’re not guessing the value.
