Anyone else seeing this one? Have had it the last couple of times I’ve logged on - paced rides. Joins the ride OK, but rather than the usual ‘Joining Robopacer’ pop-up I get ‘The destination you have selected is no longer available’ or words to that effect.
The progress bar/distance countdown in the route profile doesn’t change at the same time.
V1.92.2, iOS 18.5
I get this regularly. I think most people do. It’s just Zwift.
I’ve had it a few times, but it usually only lasts a few seconds and then I am teleported to the group
Do you have the issue where the route distance counter freezes at zero too though?
I don’t use the pacers very often but I have only seen that message in France. Are you seeing it in all worlds?
I’ve had this and the route in the mini map followed the route initially but then at a turning I didn’t follow the robopacer (i didnt steer off the route it just didn’t take the correct turn to follow that robopacer) and then the route on the mini map just showed me at the start of the route for the rest of the time.
This is when I jojned, you can see my position is a little in to the route
then this was after it steered me off the route
the marker just stayed there for the rest of the ride
Anyone find a solution to this issue? It just started happening to me and is very annoying.
Teleport to the robopacer (again) as soon as you get the Destination is not Available message. For me the second teleport has been successful.
