Tacx Fortius T1930 change resistance in Zwift
Hi cant see the Tacx Fortius T1930 in your list of trainers supported by ZWIFT. WIll the T1930  change resistance in Zwift ?
Cheers Dean
The short answer is no, it will not change resistance.
The longer answer - the older Tacx trainers use a proprietary protocol to control them, which Zwift does not support.   All the new trainers they’ve sold for the past 6-12 months with “Smart” in the name use a protocol Zwift can speak.
You can operate a Tacx Fortius / I-Magic as a smart resistance trainer on Zwift if you own two ANT+ USB dongles in conjunction with the following software: https://github.com/john-38787364/antifier
Evan,
No reason to post this in multiple threads.
