Hi
I wounder witch trainer i should choose to get the correct settings for watt estimate when I rolle in zwift land ?
https://www.tacx.com/en/products/trainers/bushido-for-tablet
Regards
R.Sand
Hi
Regards
R.Sand
The Tacx T-2790 Bushido isn’t compatible with Zwift when combined with a speed/cadence sensor, so if that’s the only equipment you have, you’ll want to pick the unlisted trainer option. This won’t give you accurate readings, but it’ll let you ride.
If you’re looking to get accurate readings with that trainer, you’ll need an ANT+ power meter (which will let you ride with any trainer). ![]()
You can see our full list of supported gear on the knowledge base.
