Hi just purchased the new tab s6 is it compatible with zwift as found it hard to connect
If Zwift is in the Google Play Store on that device it is compatible.
What sensors are you trying to connect to Zwift?
FYI, Zwift on mobile devices is Bluetooth only. If you are going to use ANT+ devices you would need a bridge like 4iiii Viiiiva HRM or CABLE.
Hi just blue tooth and not connecting may try delete and re load open to suggestions
With Bluetooth you need to make sure that the sensors are not connected to ANYTHING, including your phone/tablet before you open Zwift. Bluetooth only allows one connection to any device or app at a time.
Thanks will check never had issue with laptop but since i upgraded stopped working
