Hi all,
I’m new to zwift and have two questions.
- When out and about in swift land Iv been caught out by some of hills. Is there a way of “seeing” what’s coming up I terms of climbs.
- If I want to stick to a specific route do I just ignore the the directional prompts??
Thanks in advance.
The only real way to see what climbs are ahead is to familiarize yourself with the routes. You can sometimes refer to the bottom portion of the mini-map, but that can often be deceptive because it doesn’t always show the route you’re actually on. (Crazy, but true.) ZwiftInsider.com is a good resource for this.
And once you select a route from the initial menu, you will stay on that route unless you make a manual turn.
