I want to use Zwift with my treadmill. It is a fitifito ST100. Is it possible to connect to Zwift or how can I use it with Zwift?
Kerstin
I’ve had a look at the specs. It’s Bluetooth enabled but which may offer some options.
You could consider the treadmill speed transmitter which works by you inputting the running speed you set the treadmill at and this is sent to Zwift. You can also link a Garmin or IPhone to it and it will use the accelerometer to upload your speed.
Dependant on the Bluetooth capabilities you can use the QZ Domyos app which can read the actual speed of your treadmill and send this to Zwift.
Do you have a user manual in English?
