When doing workouts on a smart trainer that does not have ERG mode you have two options to change resistance, changing gears and changing the resistance.
So i was wondering if Zwift can help change the resistance when the training block start. I realize that it wont be perfect and that I will have to manually adjust but it could help.
So let say i do a workout and the block is at 180W then it jumps to 560W I have to change gears and increase the resistance. this is a lot of things to do especially if it is a short block. If zwift can take care of the resistance it is one less thing to do.
I realize that all trainers are different so the math will be interesting. I was thinking if Zwift look at what I am doing for one block it can just repeat that for the other blocks. Or it can increase by a factor related to the delta between current and previous block.
I’m just thinking out loud.
I don’t have a solution so any other input will be helpful.
Looking forward to hear from you.
RIDE ON!
