Hi James - lost my RCC kit when going for the Festive500
Can you pls help to re-install
James in no longer active in the forum. Please contact Zwift support directly.
I’ve seen to lost my jersey as well after opting to wear another one. Can someone help me get my RCC jersey back?
Hi @James_Zwift! Would you mind doing the same for me?
You should contact support
James in no longer active here, as Paul suggests you’ll need to contact support directly.
Hi @James_Zwift — same exactly happen to my RCC jersey, can you kindly help me re setting it? Thanks
Got it with fact that James no ll ger available here— thanks
By some reason entering Zwift Rapha challenge few months ago, next day my RCC jersey missing and since no longer available.
Can you help me having it back?
You’ll need to contact support.
Hi James, as the other lads, my RCC kit also disappeared after I joined the Rapha Festive Race. Any possibility for you to retrieve and reactivate it to my account, pls? This would be much appreciated. Best. Nicolas
James is no longer active here. Please contact support directly.
How do i contact support?
Hi, as some other zwifters, my RCC kit also disappeared after I joined the Rapha Festive Race. Any possibility for you to retrieve and reactivate it to my account, pls? This would be much appreciated. Best. Nicolas
Use the online chat bot which may be able to help or at least will allow you to submita ticket.
Contact support
@James_Zwift Could you kindly help me get my Rapha cc kit back?? Thank you in advance! Cheers
You need to contact support
Hello Zwift support
I have inadvertently swapped jerseys in the garage
I wanted return to my Rapha RCC kit for rides but some some reason it is now no longer in the garage set up. I am still a member could you add it back into my garage as a reset at your end - I see in the forums you sometimes have to do this for riders. I have triple checked and defo not there
Pressed wrong button so hand up it was user error to swap in the first place.
Many thanks in advance
