Can someone please tell me if, in the screenshot below, notifications are set to “on” or to “off”? Thanks!
On.
8 chars
When you change it to the left position (=OFF) it stays blue. That´s weird.
How to know if a toggle switch is on or off
You can see if a toggle switch is on or off by checking the position and color of the toggle. In Western culture, we read from left to right. That also applies to the toggle switch. If it is switched to the right, the switch is on.
Also, it is a best practice to have the on-state of a toggle switch use the accent color of your design.
Take a look at the examples above. You’ll see that the switched-on toggle is moved to the right and uses our purple accent color. With all actionable elements on the website also using the purple accent color, it makes a lot of sense that this toggle switch is switched on.
Possibly just not the best use of colour in Zwift’s design.
Thanks everyone! Definitely not the best use of colour design.
it confused me also!
Great Update, thanks.
How do you know if you are opted in or out of emails, as the toggle is the same in both directions?
I got the hat today and the white toggle ball is on the right in my settings.
Hey folks - we’re working on a fix for this.
In the meantime - opt in = slide the toggle to the right as @Ian_Attoe said.
