Powertap
Hello
I have a powerbeam pro smart trainer but the the power numbers are far too high to my liking. When I use zwift I have selected a combo powerbeam pro trainer for the adjustable resistance and powertap wheel for the power. Does it matter?
Shall I just use powerbeam pro in both cases and not care about the numbers. At the end if the day, work is work!
Thank you
Laurent
Hi @Laurent_Delavaine, you can use the powertap power meter for the power and then use the trainer for the controllable trainer so you get the resistance changes. Sounds like you are pairing things correctly.
:ride_on:
