It’s would be useful to be able to set an upper and lower limit on power (resistance) on smart trainers to make steady state workouts a little more life like. Atm if I want to do a zone 1 or 2 recovery ride The best I can do is pick a specific power number and the trainer forces me to stick to that. It would be good if I could define an upper and lower power limit and be able to float between those two numbers without having to be so focussed on mantaining power in a free ride.
You should be able to turn off ERG mode and use the Incline button on the Companion app or the ± keys on the keyboard to set to the desired resistance, it won’t force you to stay in a specific band but while you hold the same cadence and gear you should be in the same range.
